heckertken | -- 10-19-2011 @ 10:06 AM |
I have a '37 Sedan. I can't figure out what material was in the trunk originally. Does anyone know?
37RAGTOPMAN | -- 10-19-2011 @ 1:02 PM |
did you try Lebaron Bonney interiors they are the experts and have some kits for what you need, hope this helps 37RAGTOPMAN
trjford8 | -- 10-19-2011 @ 8:33 PM |
The trunk side panels can be obtained from LeBaron-Bonney. If you need the grained paper that goes on the trunk floor you should call Bob Drake. I believe he has it.If Drake does not have it check with some of the V-8 parts vendors listed on the front page of this site.
heckertken | -- 10-21-2011 @ 9:30 AM |
Thank you for all the info. I will check Drake's.
heckertken | -- 10-26-2011 @ 10:02 AM |
Could not find the grained paper anywhere? Does anyone have more info on this? Thank you everyone!
nelsb01 | -- 10-26-2011 @ 1:01 PM |
Roy Nacewicz used to have it. You can find his link from the main page.
trjford8 | -- 10-26-2011 @ 7:18 PM |
Roy Nacewicz can be found at; www.fordbolts.com. This message was edited by trjford8 on 10-26-11 @ 7:19 PM
42oink | -- 10-27-2011 @ 7:45 AM |
Definitely try Roy Nacewicz first! I put the paper on the luggage tray in the back of my cabriolet and it worked fine. Roy advertises in Hemmings for nuts and bolts. Get a catalog from him. He has nut and bolt sets that are correct and definiltely help when putting your car back together. The side panels Lebaron Bonney has. 'Nuff said!
42oink | -- 10-27-2011 @ 7:46 AM |
42oink | -- 10-27-2011 @ 7:47 AM |
Definitely try Roy Nacewicz first! I put the paper on the luggage tray in the back of my cabriolet and it worked fine. Roy advertises in Hemmings for nuts and bolts. Get a catalog from him. He has nut and bolt sets that are correct and definiltely help when putting your car back together. The side panels Lebaron Bonney has. 'Nuff said! This message was edited by 42oink on 11-10-11 @ 6:47 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3862 |
