parrish | -- 10-11-2011 @ 12:03 PM |
The test valve guide is real tight in the 37 chamber (just the opposite of the split guides when they flew across the garage!)...any pointers on installation? Should I hone the chamber if the solid guides are resisting? Thanks again...
supereal | -- 10-11-2011 @ 5:32 PM |
One piece guides should have a tight fit, but not need to be driven into place. Clean the guide bores well, give them a shot of spray lube and they should slip into place. This message was edited by supereal on 10-11-11 @ 5:33 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3838 |
