smokind38 | -- 09-15-2011 @ 11:51 AM |
How to remove fuel pump push rod from 1937 ford pickup v8-60. Baffle on rod precludes lifting it straight out Thanks, David
carcrazy | -- 09-15-2011 @ 11:59 AM |
You will need to remove the intake manifold first. Then you will be able to simply pull out the fuel pump pushrod.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3757 |
