mercute | -- 09-14-2011 @ 11:20 PM |
Hello again, I had a dent in the middle of my door and beat it out but had to do some shrinking. I have now ended up with a large depression in the middle of the door. What do I need to do as I have continued shrinking but the depression will not lift and just keeps oil canning. Please help, getting desperate. Thanks Mick.
supereal | -- 09-15-2011 @ 9:53 AM |
Almost always, a dent leaves a depression from the stretching of the metal. There are two ways to shrink the area. One is to heat small spots near the inside edge of the dent almost cherry red, and work inward, quenching as you go with a wet cloth. If you can fully access the back side of the dent, you can back the area with a dolly, and use a shrinking hammer. This tool has a "waffle" pattern on the head to cause the metal to be pushed together. Both methods take some practice, and may be a job for a good body shop before you make the area impossible to fix.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3754 |
