Gene N. | -- 09-06-2011 @ 1:41 PM |
59AB block best method to prepare engine for paint, presently wire brushing and sanding then clean with what then prime (with what) then finish paint green
jerry.grayson | -- 09-06-2011 @ 1:52 PM |
You must get ALL the rust and oil off first, then paint with the correct green color. No need to prime.
40guy | -- 09-06-2011 @ 2:01 PM |
I would take it somewhere and have it Hot Tanked. I must respectfully disagree on the primer issue. I would use PPG epoxy primer {or equivalent}. Also, the correct color is blue for 46-48,green for earlier.
supereal | -- 09-06-2011 @ 4:21 PM |
We don't prime engines before painting, but it is important to get all the oil film off. A good solvent is carb or brake cleaner. Be careful, as these solvents are usually quite flammable. We use it even if we hot tanked the block.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3715 |
