jerry weiser | -- 09-01-2011 @ 2:06 PM |
will my ford run cooler on distilled water. suggestions? weezer
ford38v8 | -- 09-01-2011 @ 2:21 PM |
Jerry, I'm tempted to make a funny here... but to answer your question, any car will run cooler over the long haul if distilled water is used rather than tap water. The reason is that tap water will leave calcium deposits throughout the system, preventing heat transfer. If you live in a moderate temp region, distilled water and water pump lubricant will do well for you without antifreeze. Some also recommend a product called "Water Wetter" which, along with similar products, leaves an oily film on all surfaces to prevent hot spots in the engine. I believe this product also has the required anticorrosion agents. Alan
Stroker | -- 09-01-2011 @ 2:32 PM |
Weezer: Alan pretty well covered it, and I don't use tap water to mix with anti-freeze either. One additional benefit of distilled water is that it also reduces hydrolysis, which can be a problem if you are running aluminum heads. Since you do live in a mild climate, eliminating the anti-freeze component will increase the heat transfer rate of the coolant. The only downside is that it will also lower the boiling point.
Edited to remove double post. This message was edited by Stroker on 9-1-11 @ 2:33 PM
supereal | -- 09-01-2011 @ 5:06 PM |
Using "demineralized" water is equal to, or better, than distilled water. It is the deposit of minerals, primarily "lime" that reduces the effectiveness of engine cooling systems.
MG | -- 09-01-2011 @ 6:22 PM |
For the past 20 years I've mixed water soluble oil with demineralized water in all three of my Flatheads. It turns the water milky white and if it stays that way, it's a good indication of the cleanliness of your cooling system. This message was edited by MG on 9-1-11 @ 10:17 PM
jerry weiser | -- 09-02-2011 @ 9:07 AM |
where can i find it? weezer
MG | -- 09-02-2011 @ 9:58 AM |
The demineralized water can be found in most super markets and the soluble oil in most auto parts stores. Directions for the proper mix can be seen on the soluble oil container. This message was edited by MG on 9-2-11 @ 11:13 AM
jerry weiser | -- 09-07-2011 @ 4:55 PM |
MG do you mean radiator lube/anti-rust stuff on a shelf at auto zone? weezer
MG | -- 09-07-2011 @ 7:32 PM |
Jerry, This is what I'm referring to, what I use. Click on this link: http://www.crcindustries.com/ei/content/prod_detail_print.aspx?PN=SL2512 NAPA Add: https://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=SLRSL2512_0006410058&An=0 This stuff at Auto Zone claims to be water soluble oil as well. See: http://www.autozone.com/autozone/accessories/Bar-s-12-oz-water-pump-lube-with-anti-rust/_/N-262g?counter=12&itemIdentifier=248595_0_0_ This message was edited by MG on 9-7-11 @ 9:57 PM
jerry weiser | -- 09-08-2011 @ 6:36 PM |
thanks all. weezer
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3695 |
