Verloop | -- 09-01-2011 @ 3:28 AM |
At a recent Motor Vehicle Inspection in Germany, it was advised to replace the Stabilizer Swivels and related parts. Could someone give me some advice, which parts to replace, to tighten things up a bit und which vendor is recommended? Thanks. Peter Verloop
40 Coupe | -- 09-01-2011 @ 4:46 AM |
The front stabilizer rubber bushings (2) 11A-3558, the swivels RH is 01A-3533-A and LH is 01A-3534-D. The swivels fit onto the perch pins and the stabilizer bar. In the perch pin is a front spring shackel 51A-5464 they are sometimes worn and loose. If the shackel has to be replaced the old can be cut and beat out but the new has to be pressed in.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3692 |
