doning | -- 08-30-2011 @ 4:30 PM |
Took the '37 Ford out for a drive the other day and no issues. The next day I tried to take it out and had a hard start. I had no gas coming out of the nozzles when I moved the throttle by hand. I removed the carb top and my float was way down in the bowl. For a test I filled the bowl back up with gas and replaced the top. I checked it the following day and the fuel was right up to the top. I took it for another drive and then shut it down. The next morning the bowl was half empty. There are no internal or external leaks anywhere. I replaced the accel. pump, power jet and a new Grose needle and seat. Where is my gas going just sitting overnight? Thanks, Don
ford38v8 | -- 08-30-2011 @ 5:27 PM |
Doning, It looks like you've covered most possible causes, the only one I can think of that is still left is heat soak boil out. Without the water circulation and air from the fan, your engine compartment is a bakery. Today's fuel being highly volatile, it evaporates quickly even without heat soak. Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3684 |
