ramino | -- 11-24-2009 @ 9:45 AM |
what could go wrong now on my 1938 Ford Pickup?? Any ideas?? Thanks,
37RAGTOPMAN | -- 11-24-2009 @ 4:47 PM |
hi need more information, how is it the rest of the gears ? does it have power in them? what was the last thing you did to it,??? 37RAGTOPMAN
ramino | -- 11-25-2009 @ 8:41 AM |
thank you for getting back to me. When is in first gear, it lags for acceleration. Giving it more gas to pick up speed in first gear, creates back fire!!! I took the carb out, and cleaned the injections. it is still does the same thing after i installed the carb!! Do you think i should add more transmission oil?? or it has to do with the fuel and carburetor?
oldford2 | -- 11-25-2009 @ 5:39 PM |
I THINK THIS GUY IS PULLING OUR LEG
JebNY | -- 11-25-2009 @ 6:06 PM |
I think it is his muffler bearing. Jim... 1950 F1 Stake
supereal | -- 11-25-2009 @ 6:27 PM |
To give any suggestions, we need to know the type of engine. That is, does it have 24 or 21 cylinder head studs? What type of carb is installed? What is the rear axle gearing? Has it been converted to hydraulic brakes? Does it have what appears to be an original ignition coil? Without that information, I'd suspect that you may have a poor or open ignition condenser. That will cause lack of power and backfiring.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=367 |
