40cpe | -- 08-11-2011 @ 12:53 PM |
This is probably the first of a series of questions. I'm trying to replace the window felts in the doors of my club coupe, which I understand is the same as a 2-door. There is a peg, for the lack of a better term, in the window channel that prohibits the window coming out the opening. I have the nut and washer removed from the "peg" but it just spins in the hole and will not come out. It acts like there is a circular grove in the bolt where the bracket is. The window will not come out the bottom because there is a closed bottom on the front felt channel. Maybe I'm going at it entirely wrong. Any help appreciated. This message was edited by 40cpe on 8-11-11 @ 1:23 PM
G Tosel | -- 08-11-2011 @ 3:05 PM |
The peg you are talking about is also threaded into the channel. There should be a slot in the end of the peg to use a screw driver to remove. Might need a plier or vice grip to remove.
40cpe | -- 08-11-2011 @ 3:31 PM |
I've tried to thread it out, even pulled on it while turning. It just spins in the hole. I would think by pulling on it the threads would catch and begin to back out, but no. So I have an abnormal situation here?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3570 |
