36fordor | -- 08-08-2011 @ 6:49 AM |
What would have been original and/or recommended fuse size for stock 36 Fordor? Thanks.
doning | -- 08-08-2011 @ 7:16 AM |
I believe I have a 20 amp. in my stock '37 fordor.
Don Rogers | -- 08-08-2011 @ 3:25 PM |
Ford specified a 20 amp 3AG glass fuse
supereal | -- 08-09-2011 @ 10:06 AM |
The original part (01A-12250) was a breaker assembly for the lighting that had two sections, A 15 amp for all but the headlights, and a 30 amp side for those. This was used from '33 thru '48 in various configurations, and had the ignition resistor as a part of the unit.
tudorbilll | -- 08-09-2011 @ 11:15 AM |
They 35-36 book shows something quite abit different. the fuse is for the lighting only,every thing else is fuse free,car will run with blowen fuse.I have two stock 35,s that are wired just the way its shows. works for me & the fords. 20 amp fuse This message was edited by tudorbilll on 8-9-11 @ 11:18 AM
Don Rogers | -- 08-09-2011 @ 11:41 AM |
Supereal, The 01A-12250 fuse block didn't come out till 1940 and most likely had different fuse requirements than the earlier units. The 48-12250 fuse block was very simple (crude) and only included a fuse and resistor. Here is my image frome the 1935-36 Ford Book. Regards, Don Rogers Author 1935-36 Ford Book
supereal | -- 08-09-2011 @ 1:43 PM |
Thanks Don. I was going by the green book, which shows several types of the "breakers" for cars and trucks after '32, as do my books of wiring diagrams, and I stand corrected. From your pic, I can see that the "breaker" shown is, as your picture shows, the back side of the strip. Apparently, the term "breaker" is interchangable with the term "fuse" at Ford. I still think 20 amps is a bit low for the headlights when coupled with all the rest of the lighting system. I'd use a 30 to be sure, in any case. We replace the "breakers" in most cases with push button reset modern breakers mounted up high on the inside of the firewall. For those planning to install a fuse or breaker, don't fuse the charging circuit. If you want to be sure that old wiring does't set your car on fire, add a master switch on the battery post. This message was edited by supereal on 8-9-11 @ 2:48 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3542 |
