doning | -- 07-31-2011 @ 3:54 PM |
I want to replace my outside door handle gaskets on the doors of my '37 fordor. If I loosen and remove the two screws will the handles pull right out? Thanks again! Don
MG | -- 07-31-2011 @ 5:37 PM |
Yes.....
supereal | -- 07-31-2011 @ 7:25 PM |
If the square shank of the handle is worn from use, it may take some fiddling to get it out of the latch, particularly if the square hole in the latch is loose.
doning | -- 08-01-2011 @ 1:58 AM |
Thank you.
trjford8 | -- 08-02-2011 @ 8:52 PM |
The handle will need to be tipped down slightly and then you can pull it out.
doning | -- 08-03-2011 @ 1:58 AM |
Okay. Thanks again Guy's.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3500 |
