Paul | -- 07-03-2011 @ 2:00 AM |
Please advise as to what brand(s) of motor oil that I can/should now be using in my '51 Lincoln Cosmopolitan engine. Located in Ontario, so it must be available in this area.
trjford8 | -- 07-03-2011 @ 7:46 AM |
I use Castrol and would assume it's available in your area.
TomO | -- 07-03-2011 @ 10:44 AM |
Any major brand of oil should give you good service in your Lincoln. I use Castrol 20w-50, now but have used Pennzoil 20w-50 in the past. Tom
51f1 | -- 07-03-2011 @ 2:25 PM |
There is more nonsense about motor oil than just about anything else I can think of. Any good brand of multi-viscosity oil will do. Walmart sells several brands. Take your pick. Castrol and Pennzoil 20w-50 sound good to me. Richard This message was edited by 51f1 on 7-3-11 @ 2:29 PM
ford flathead | -- 07-03-2011 @ 2:52 PM |
I recommend Valvoline 20-50 VR1. It is the racing oil and it sells everywhere. It has high zinc in the oil which is better for flat tappet engines.
BERTHA | -- 07-03-2011 @ 5:12 PM |
http://www.amsoil.com/storefront/zrf.aspx
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3332 |
