zeker8 | -- 11-17-2009 @ 4:42 AM |
I'm doing the conversion on my 37 to 48 drum brakes, any info on the master cylinder, drum/drum type, that will mount to the 39 bracket with the adapter to two bolt would be helpful. Thanks Zeke
alanwoodieman | -- 11-17-2009 @ 6:36 AM |
I used a 68 ford pick-up dual master cylinder for my 41 truck I had to make an adapter to mount the cylinder. master cylinder had two mount points, pedals had three
trjford8 | -- 11-17-2009 @ 7:59 AM |
Chassis Engineering (www.chassisengineeringinc.com) has the adapter bracket that you need.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=328 |
