ellis734 | -- 06-19-2011 @ 6:54 AM |
I have a 1938 Ford sedan with the 85 hp engine. I just replaced the oil pan gasket and am ready to add new oil. What grade of oil should I use?
tudorbilll | -- 06-19-2011 @ 8:58 AM |
A lot of us use 20-50 also 15-40 is ok. if it gets into 90,s where your at stay with 20-50
supereal | -- 06-19-2011 @ 9:32 AM |
I agree. I use Castrol 20W-50, as it is readily available. If not, Sh*ll Rotella 15-40 will work. It helps to keep oil pressure up somewhat when the engine is hot. Castrol comes in 5 quart jugs, while the Rotella is in gallon containers. Four quarts is correct for your 85HP unless it has a filter, then 5 quarts is the correct fill, so if you have a filter, and buy Rotella, get an extra quart.
ellis734 | -- 06-19-2011 @ 5:58 PM |
Thank you, 20w-50 it is then.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3262 |
