carcrazy | -- 11-15-2009 @ 12:04 PM |
Is there any advantage to using the "straight" water pumps rather than the "tapered" kind that originally came on a 1937 Ford V8-60 engine? I know that the compatible front timing gear cover will have to be obtained to use the straight pumps. Are new and/or rebuilts available for both kinds of water pumps?
trjford8 | -- 11-16-2009 @ 7:02 AM |
I don't believe you can get new pumps for a V-8 60.You might find som NOS pumps and there are rebuilt pumps available.
supereal | -- 11-16-2009 @ 9:01 AM |
The only source we found for 60hp water pumps is Little Dearborn (888/282-2066). The earlier, tapered type had leakage problems, so it you are planning to convert, the later style would be preferable. I don't know where you would locate the front mounting plate if that is required.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=314 |
