parrish | -- 05-25-2011 @ 6:58 AM |
Are there decent reproductions available or do all the vendors have the same supplier? The samples I've seen were pretty thin metal...
trjford8 | -- 05-25-2011 @ 8:21 AM |
There are different manufacturers of the hubcaps. As an example there is a noticeable difference between the 41 hubcaps made by Drake vs Vintique. You should ask the V-8 vendors which caps they carry. I'm also aware that some of the repo caps will not fit some of the aftermarket wheels. I will say the repo stainless caps are far superior than the old chrome steel caps from Argentina. I recall the old Argentine caps from J.C. Whitney did not have the Ford script. The script on those caps said "FOOL".
parrish | -- 05-26-2011 @ 6:52 AM |
what are the differences in your opinion?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3128 |
