ole_Bill | -- 05-22-2011 @ 5:48 AM |
I need a cylinder head bushing for the tempature probe on my 59A with Edelbrock heads. I tried Edelbrock tech and got zero help. Currently running an ad in classifieds, but no response to date. Can anyone tell me where I might acquire this item?
trjford8 | -- 05-22-2011 @ 9:33 AM |
Bill check you local auto parts store or speed shop in your area. Most carry the brass bushings for temp sensors, etc. Most often those bushings are a pipe thread so you may even find one at a hardware store.
37RAGTOPMAN | -- 05-22-2011 @ 9:37 AM |
try a plumbing supply store, if a GOOD hardware store does not have it, hope this helps 37RAGTOPMAN
supereal | -- 05-22-2011 @ 10:19 AM |
Bill: C&G shows a head to sender bushing as B4A-10911-A. It is for the later engines, but may work for the earlier senders. Both the head and the sendere use a pipe thread, so the recommendations of looking at a hardware store might work, if they have the brass variety, rather than the steel.
ole_Bill | -- 05-23-2011 @ 10:02 AM |
Unfortunately, the bushing has to be flared both inside and outside in order to seal properly. I have one of the straight pipe thread bushings and it leaks water - a lot of water.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3105 |
