MG | -- 05-05-2011 @ 5:34 PM |
I'm replacing the gas tank sending unit. The replacment unit came with a cork gasket as is the original gasket. Do I wipe this cork gasket with grease or do I have to use some sort of gasoline-proof sealant.
ford38v8 | -- 05-05-2011 @ 5:41 PM |
MG, Cork gaskets respond well to an oil bath. I like especially to oil the gaskets on a fuel pump to soften them and eliminate possible air leaks. No reason why this method wouldn't work in your case. Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3028 |
