SDExpoman | -- 05-05-2011 @ 1:01 PM |
I picked up a set of replacement pads for my '37 truck from C&G. I changed out the clutch pad okay. However when attempting to change the brake pedal pad, I noticed a someone had welded on a different sized piece to the brake arm bottom. The hole diameter is a smaller thread than stock, however the pedal is the same size/shape on top. Any clues as to what years used the smaller sized threaded attachment? Hmmmmm.....
supereal | -- 05-05-2011 @ 6:09 PM |
As the hole is smaller than the stud on the pad, drill out the hole and thread it for the new pad.
SDExpoman | -- 05-05-2011 @ 6:18 PM |
Perhaps as a last resort. But if there is one that has the smaller thread it's an easy swap.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3021 |
