V8garage | -- 05-04-2011 @ 1:27 PM |
Does anyone out there know what size castle nut that I need for a 42 to 47 open drive banjo rear end. The nut is the one that holds the u joint yoke to the spline. I had to cut mine off and now cannot replace it. The size appears to be 15/16th fine thread. Better yet if someone can help me to locate the correct nut. Thanks
supereal | -- 05-04-2011 @ 3:13 PM |
You need a 7/8" X 20 thread castle nut The nominal measure is 1/2" X 1 1/4".
V8garage | -- 05-04-2011 @ 5:36 PM |
Thanks for your quick response!!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=3014 |
