MOXIE | -- 05-02-2011 @ 3:58 PM |
Does someone have a 35 drive shaft loose that you can give me a dimension. I've found one but the female coupling end appears to be to long. I do not have mine disassemble. If you do, could you give me an overall dimension length of the shaft and a dimension from the centerline of the 1/4" pin hole to the groove for the snap ring at the male end, thanks
37RAGTOPMAN | -- 05-03-2011 @ 10:29 AM |
in your 35 you should have a hollow driveshaft.with a 10 spline pinion shaft gear,the drivehshaft tube will not have a grease fitting, the one you are asking about, do it have a grease fitting on the driveshaft tube,? hope this helps 37RAGTOPMAN
supereal | -- 05-03-2011 @ 1:24 PM |
Ford only used one size of hollow drive shaft. When we modify a shaft for a six spline coupler, we measure the shaft first and use that for the length.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2994 |
