trb41 | -- 05-01-2011 @ 11:15 AM |
Have Ford Script Repo battery. Need to replace. Anyone know of a battery that will be the same size as repro I can get. Size is 10 1/2 long, 7 wide, 7 high (from bottom of case to the top of case-not to top of battery terminal). Should be listed as 2LF series battery.
tudorbilll | -- 05-02-2011 @ 12:26 AM |
tudorbill hope this helps,also try NAPA, or any auto parts store try http://turbostart.com/ ON their web site go to collecter series. this should help you out, the battery will be FORD SCRIPT,and will fit with no problems,and will taken care of,aleast 5 years maybe longer, just check your generator out put so it is NOT Overcharging,this will make last much longer. hope this helps 37 FORD RAGTOPMAN, This message was edited by 37RAGTOPMAN on 4-12-11 @ 5:06 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2985 |
