MICHV8 | -- 04-25-2011 @ 7:02 PM |
Will the newer style 1937 waterpumps (dual function as motor mount and waterpump) fit a 34 frame without alteration? Thanks.
BrianCT | -- 04-26-2011 @ 7:34 AM |
You will need a pair of spacers that go between the mount and pump flange. Others may suggest a source.
trjford8 | -- 04-26-2011 @ 7:46 PM |
Brian is correct about the spacers. You can get them from Speedway Motors.
MICHV8 | -- 04-28-2011 @ 9:04 PM |
vertical spacing is only issue? horizontal measurements match up? thanks.
MICHV8 | -- 04-28-2011 @ 9:05 PM |
MG | -- 04-29-2011 @ 1:16 PM |
I used the motor mounts out of a '55 Chevy when I put a 59AB in my '34 3 Window by in 1965.
trjford8 | -- 04-30-2011 @ 8:33 AM |
Horizontal should match up. If they are off a little you make adjustments by making the holes in the spacers oblong. This message was edited by trjford8 on 4-30-11 @ 8:34 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2966 |
