avrotom | -- 04-18-2011 @ 1:33 PM |
Am having difficulty getting the correct trust washer for the rear of the cluster gear. 68-7129-B is the rite OD and appears to be the rite thickness but there it ends. The one I need has a larger center hole with 2 flats. Major ID is 1.52 inches with across the flats ID of 1.40 inches. The case matches the frame serial no. Is this another "Canadian Car" anomoly? Any help will be appreciated. Tom
40 Coupe | -- 04-18-2011 @ 5:26 PM |
If your using the 51A-7113 or 8M-7113 cluster you need Both 8M-7129 and 8M-7128 they have the larger hole for the two wide tangs on the cluster, they are used together with 7129 on the inside.
JM | -- 04-20-2011 @ 7:18 AM |
Contact Mac VanPelt. He has a great website where you can probably look up what you need then contact him for the part. http://www.vanpeltsales.com/FH_web/flathead_home.htm If by chance Mac can't help you, try Charlie, NY who posts on Fordbarn JM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2936 |
