SDExpoman | -- 04-16-2011 @ 9:38 PM |
What type of chassis lube should I use for my '37 half ton? I went to NAPA today, and all I could find is an all purpose lithium.
supereal | -- 04-17-2011 @ 10:02 AM |
I use Mystik JT-6. It is an all purpose grease that is virtually waterproof. We started to use it many years ago for boat trailer bearings, which have a high failure risk if wet, and found it to be good for almost everything else, except Ford rear wheel roller bearings, which require the "heavy duty drum brake" variety with the fibers. We buy JT-6 at a local farm supply in cases of 10 tubes, but you can buy individuals, too.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2927 |
