Ron Crouch | -- 04-16-2011 @ 2:05 PM |
I just bought a radiator cap off e-bay that was supposed to fit my 1936 Ford Sedan flathead v-8 and the portion of the cap that goes into the radiator filler hole is slightly too large. The cap is square with ears and says WATER evrseal no P-2. Any suggestions.
Don Rogers | -- 04-16-2011 @ 3:32 PM |
The R-2 Everseal cap is not for the Ford V-8. You need the R-1. See attached image.
Ron Crouch | -- 04-16-2011 @ 6:55 PM |
Thanks
1942deluxe | -- 04-20-2011 @ 8:24 AM |
I have three 48-8100 nos caps which is correct in the "green bible".Similar shape but has what I'd describe as like a spring handle on top.If you still need one call me at 570-875-4417 and ask for John Kelley.Don't have a good way to take a picture but can describe it for you.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2924 |
