Wolfie | -- 04-12-2011 @ 8:34 PM |
How difficult is it to remove and reinstall the hood without scratching the paint? It looks like a five man job. Four to carefully lift the hood and one to remove the bolts. Do the springs have much tension on them? Thanks!
40guy | -- 04-13-2011 @ 6:57 AM |
I've did it this way many times. 1-raise hood. 2-cut safety wire from back bolts { if it's still on there } 3-place a quilt or other such THICK covering over the cowl and fenders. 4-have someone hold the front of the hood as you remove the spring arms from the hood. tha springs don't have any force on them with the hood up. 5-remove four rear bolts from back of hood. 6-lift off hood. I've never used 5 people to do this; usually 3 and have done it with 2 if the hood is proped in front with a rod. It's not a big deal, but use as many people as you feel comfortable with.
Wolfie | -- 04-13-2011 @ 2:37 PM |
Thanks 40guy. That was a lot of help.
Turks46 | -- 04-17-2011 @ 11:26 AM |
I've actually done it using three winch straps suspended from the garage rafters to the nose and two hood corners. The winch mechanism on the corners makes it a bit easier on small adjustments while you undo the side bolts. Just make sure the strap connections are secure.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2910 |
