Flatbob | -- 04-08-2011 @ 1:22 PM |
Can someone tell me what purpose the hole on both sides of the fork serve if any? Am trying to piece together a '49-'53 stamped one piece bell housing.
TomO | -- 04-09-2011 @ 9:15 AM |
The parts catalog shows that they are used for the anti-rattle spring. Tom
Flatbob | -- 04-09-2011 @ 1:06 PM |
TomO, thanks for replying. What catalog do you have? Don't see it listed in the C&G catalog, would this be a NAPA part? Do you have a part #?
TomO | -- 04-11-2011 @ 5:12 PM |
I looked it up in the Ford Chassis Parts manual for 1949-1953. The arm is P/N XX-7515 where XX is 8A for 49/50, 1A for 51 and AB for 52/53. The spring is XX-7562 with 8A for 49-51 and AB for 52/53. Tom
Flatbob | -- 04-11-2011 @ 8:10 PM |
TomO thanks, will see if I can locate these springs. Does the manual show if one or two springs is used? I have a hole on each side of the clutch release fork arm so I thought it might use two. Went to Vanpelt site & now I see how everything goes together. This message was edited by Flatbob on 4-12-11 @ 8:03 AM
TomO | -- 04-12-2011 @ 8:37 AM |
There is one spring that goes from the top hole to the bottom hole. Unfortunately VanPelts site does not have the P/N on it. The spring is shown as a wire just behind the arm by the holes. Tom
Flatbob | -- 04-12-2011 @ 4:13 PM |
I couldn't find a part number either & don't see it in any of the usual supplier catalogs either. Sent a picture to a salvage yard, hope he has one.
TomO | -- 04-13-2011 @ 9:32 AM |
Give Mac Vanpelt a call, he may have one or tell you where you can get one. Tom
supereal | -- 04-13-2011 @ 10:21 AM |
Another potential source is Birdhaven. They specialize in "showbox" parts. 515-377-5319.
Flatbob | -- 04-13-2011 @ 2:28 PM |
Thanks everyone, will check out info. provided.
Flatbob | -- 04-15-2011 @ 2:06 PM |
Got the spring from MARTIN SUPPLY AND SALVAGE. Charles probably has whatever your looking for.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2895 |
