Pair of 40's | -- 04-01-2011 @ 6:59 AM |
What weight and type is recommended for my 40 ford 3 speed transmission. Car is driven only in warm weather. Thanks
supereal | -- 04-01-2011 @ 10:30 AM |
Any brand name 80W-90 gear oil is acceptable, but we prefer the straight 140 weight. It stays in the transmission better than the lighter oil. While there is a rear seal, and a slinger, the Ford gearboxes usually leak considerably, either or both on your driveway, and down the torque tube. 140 is a bit heavy for colder climates, but for most of us, it has the added advantage of making shifting somewhat smoother by slowing the cluster gear down a bit between shifts.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2851 |
