Gene N. | -- 03-30-2011 @ 6:50 PM |
Looking for Sta-lube I believe the number is SL3131 Napa used to sell it but here in Pa. they no longer carry it Where can I get some Gene N.
ford38v8 | -- 03-30-2011 @ 7:04 PM |
Gene, it's amazing the things you can find online. http://www.amazon.com/CRC-SL3121-Marine-Trailer-Bearing/dp/B000CPJMY8 Alan
thirtysixford | -- 03-30-2011 @ 7:48 PM |
Alan You are so right Sure makes finding things a snap Mike
Gene N. | -- 03-31-2011 @ 6:01 PM |
Thanks Guys but that is 3121 I need SL3131 brake grease (heavy Duty)
39 Ken | -- 04-01-2011 @ 4:27 AM |
NAPA may not have it on the shelf but they can order it.
ctfordguy | -- 04-01-2011 @ 5:53 AM |
Hi Gene, Sorry I don't know how to transfer the link. Just go to AMAZON.COM and type in SL31321......It's there for $ 2.99. Cheap enough Good luck. Bruce/CT
ford38v8 | -- 04-01-2011 @ 12:18 PM |
Bruce, easier than that, just type it into google and then choose from the list. As for transferring a link, all that involves is to highlight the url address, and then drag it to the post. Gene, sorry I misread your request as 3121. Alan
37RAGTOPMAN | -- 04-02-2011 @ 5:29 AM |
I would think any trailer or RV store will carry a grease that will do the bearing, it would be local and have some to choose from.and NO SHIPPING, My 3 cents worth 37RAGTOPMAN
Gene N. | -- 04-02-2011 @ 8:01 AM |
You guys are great I am glad I belong to the V8 ford club Thanks Gene
supereal | -- 04-02-2011 @ 10:57 AM |
The rear hub roller bearings require fibrous grease that pulls the lube thru and around the rollers. Any other type will result in damage to the axle housing. Ordinary grease is OK with the Timken tapered rollers, but the Hyatt bearings need more than just a film. If it isn't the heavy, sticky yellow grease, don't use it.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2840 |
