4ford | -- 03-26-2011 @ 11:30 AM |
hi do you when installing winshild and rear glass in a 1941 ford add sealer to the rubber?? or just rope it in. thanks 4 ford
supereal | -- 03-26-2011 @ 2:15 PM |
The sealer (we use 3M) goes under the lip of the gasket on the outside of the car. Lift up the edge of the rubber and put sealer underneath. We mask off the area around the gasket to make cleanup easier.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2810 |
