DJACK | -- 03-06-2011 @ 5:47 PM |
NEED TO REMOVE THE FRONT TIMING COVER. HOW DOES THE CRANK PULLEY COME OFF? THANKS DENNIS
37RAGTOPMAN | -- 03-06-2011 @ 6:02 PM |
remove crankshaft rachet nut and slide off forward,,, BECAREFULL do not harm the radiator. use some cardboard to protect it, hope this helps 37 RAGTOPMAN
DJACK | -- 03-06-2011 @ 6:16 PM |
How do you remove the nut? Thanks Dennis
DJACK | -- 03-06-2011 @ 6:20 PM |
I see the nut is it left or right hand theard?
Tom/SC | -- 03-06-2011 @ 8:33 PM |
Dennis the bolt has a hex head and loosens to the left. It has tangs on the bolt to accept the hand crank. Often that bolt has been replaced by a regular hex head bolt. Tom
supereal | -- 03-06-2011 @ 8:41 PM |
You will need to have a new rope seal and timing gear cover gasket. If you are not using the Teflon type rope, be sure to soak the seal in oil for a couple of days before installation, and don't trim the ends when the cover is replaced, after being sure the seal is fully seated in the groove. You can do this by rolling the seal with a round object, like a hammer head, to seat it. Put a dab of sealer on the end of the seal before installation to reduce oil leakage.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2714 |
