ole_Bill | -- 02-14-2011 @ 2:23 PM |
Can anyone tell me what goes in the threaded hole below the oil dipstick tube in this picture? The pan fits a 59 block.
supereal | -- 02-14-2011 @ 2:48 PM |
No mystery there, Bill. That is a return for an oil filter. Some dipstick bosses alread have the pipe threads for a fitting, while others must either be replaced, or a separate boss installed to accomodate the return line. Most 59A pans have the former.
ole_Bill | -- 02-15-2011 @ 8:54 AM |
Since I plan no oil filter I assume this hole may be plugged. Do I use a sealent like thread tape or maybe gasket sealent on the plug?
supereal | -- 02-15-2011 @ 11:05 AM |
Usually those holes are pipe threaded, and need no sealer. The oil there is not under pressure. If the plug tightens down, I wouldn't put anything on it. At our shop, we don't use Teflon tape. It has a nasty habit of clooging vital areas if any of the tape breaks off. We do use some Permatex if any is required.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2594 |
