MICHV8 | -- 02-13-2011 @ 9:22 AM |
Does the scuff plate attach directly to the sub-rail or is there a separate rocker panel in addition to the sub-rail? EMS has a rocker panel that looks very much like a sub-rail...
40 Coupe | -- 02-14-2011 @ 11:53 AM |
For 36 the scuff plate screws to the side of the rocker pnls. It seems that many use "subframe" for "rocker" I have also heard subframe in mention to the floor stiffeners welded to the underside of the floor. the rockers start at the end of the toe board and end in the trunk or rumble area.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2585 |
