john38coupe | -- 02-10-2011 @ 6:29 PM |
Does anyone know a good product to use to match/duplicate the (looks like) black spray on sound deadening that HENRY used inside door panels, trunk sides, etc. Any Judging experience is appreciated.
alanwoodieman | -- 02-10-2011 @ 8:19 PM |
it was ashault based and was more or less sprayed/splatted or roughly brushed on the surfaces. Some of the undercoatings made by 3M are a match, but remember the original changed with age-depending on where you live, some has hardened and cracked, some peeled off, even some pretty well survived
trjford8 | -- 02-11-2011 @ 6:56 PM |
Since you don't see these areas where you apply the sound deadening material, I would use the material that they use for bedlining in pickups. You can buy it at Walmart by the quart and roll it on with a roller. You can also get it in spray cans.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2572 |
