46fordnut | -- 01-17-2011 @ 7:36 AM |
does anybody know where and how much i can get a wiper transmission for a 1946 ford closed car. i also need the kit to bolt it into place. just found my vac wiper motor is also no good.
Old Henry | -- 01-17-2011 @ 8:20 AM |
Those kind of parts that aren't sold new by the usual suppliers I find on ebay. I just looked and didn't see the transmission at this time but did see several vacuum motors here: http://motors.shop.ebay.com/i.html?_nkw=1946+ford+wiper+motor&_sacat=&_sop=10&_dmd=1&_odkw=1947+ford+wiper&_osacat=0&bkBtn=&_trksid=p4506.m270.l1313 Old Henry (The older I get, the better old looks.)
TomO | -- 01-17-2011 @ 9:18 AM |
Dennis Carpenter used to advertise the arms and may still have some left for the Trico set up. The P/N is 51A-17552 and 51A-17553. He also had the nut, bezel and gasket. Tom
rdove | -- 01-17-2011 @ 9:36 AM |
Give Ficken Wiper Service a try. www.wiperman.com or 631 587-3332.
supereal | -- 01-17-2011 @ 11:29 AM |
C&G 800/266-0470) has a 6 volt electric conversion in their catalog. The 46-48 model is 51A-17508-HD6. They are a bit pricey, at near $200, but locating and fixing the lame vacuum motor isn't cheap, either. Their conversion will fit a car with the original radio. Some, such as the 41-42, will not.
46fordnut | -- 01-17-2011 @ 2:54 PM |
ok thanks ill check
46fordnut | -- 01-17-2011 @ 5:24 PM |
i did call this wiper guy about 1 year ago. to see if he had whats called a wiper "drums" . he said he keeps them in his top sock drawer and then hung up on me.
jerry.grayson | -- 01-18-2011 @ 6:45 AM |
I don't know what wiper "drums" are and maybe the guy thought you were putting him on.
46fordnut | -- 01-18-2011 @ 8:01 AM |
the parts where the wiper arms attach to the wiper trans. the part that shows throu the cowl.
TomO | -- 01-18-2011 @ 3:54 PM |
On the Trico system, there are 2 arms that attach to the wiper motor, there is a bell crank on the end of these arms that is attached to the shaft that goes through the cowl for attaching the wiper arms. Is this the part you are looking for? Tom
46fordnut | -- 01-19-2011 @ 11:36 AM |
small round piece that comes through the cowl has some rough stuff to help keep the wiper arm not slip.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2462 |
