carcrazy | -- 01-14-2011 @ 5:29 PM |
Hi, Does anyone know of a source for the the tool (spanner wrench) required to remove and install the water pumps on the 1937 to 1940 Ford V-8 60 HP Engines? If the original type of tool is no longer available is there another type of tool with movable member that will work? Please let me know. Thank you.
supereal | -- 01-15-2011 @ 9:47 AM |
You may be able to grip the collar with large water pump pliers. I haven't seen one of the tools for many years. The '37 pumps were different than the later 38-40, and the short production meant little attention was given to replacement. We have purchased 60HP parts from Little Dearborn, and they may be able to help. 888/282-2066.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2444 |
