bwhitworth | -- 01-09-2011 @ 2:13 PM |
I want to put 15" alum rims and tires on my 40 coupe. How do I know what sizes to buy? I know the bolt pattern is 5 on 5 1/2". How wide should the rim be and the amount offset? What size tires would you suggest? Thanks Bob
shogun1940 | -- 01-09-2011 @ 7:12 PM |
see if you can borrow a ford truck rim it has the same bolt pattern, 15" 16" you can mesure from there. I have 31" 15"dia. on the back of my 40, 8" wide tires, the back spacing is key
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2417 |
