dansford | -- 01-01-2011 @ 6:54 AM |
I just purchased a radio for my 36 Ford Deluxe where is the best place to supply the power to it under the dash? Thanks and Happy New Year. dansford
trjford8 | -- 01-01-2011 @ 8:05 AM |
Use the column switch. The power wire needs to be on a switched source so when the switch is off the radio goes off with it. This keeps the radio from being accidently left on and draining the battery.
40 Coupe | -- 01-02-2011 @ 5:03 AM |
Ford wired the radio to the unfused side of the fuse under the dash. There should be a inline fuse in the radio power wire. The original radio used a bit of current and putting that current through the original ignition switch may cause premature failure of the switch.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2370 |
