Pair of 40's | -- 12-31-2010 @ 1:07 AM |
I'd like to have a list of flathead, head casting numbers by the year they were built, 59, 59ab etc. Thanks
nelsb01 | -- 12-31-2010 @ 8:40 AM |
This site should help you............ http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm
Pair of 40's | -- 01-02-2011 @ 11:35 AM |
Thanks, I looked over the info refered to but still not sure. My heads have the numbers 59A 6050B. Can you tell what year they were mfg?
supereal | -- 01-02-2011 @ 1:23 PM |
Usually, they are for '42-'48. I say "usually" because a lot of head swapping was done over the years, and the 59A-6050A was used from '38 until sometime in '42, then the "B' style was used and furnished as a replacement for all 24 stud dome piston engines. To my knowledge, there is no way to determine the exact year of manufacture, other than that period set out above.
ford38v8 | -- 01-02-2011 @ 7:00 PM |
Bob, you must have had too much new year party. 59 blocks and heads were post war only. 81A for '38 & '39, A for '40-42. Pair of 40's, the number 6050 is the part number only. If you shine a bright light at the engine bell below the dash, you will likely see a large cast 59. Look at Van Pelt's website for specs of your engine. Alan
supereal | -- 01-03-2011 @ 10:22 AM |
No, Alan, I'm still standing. What I was saying, if not too clearly, is that the 59A & B heads were furnished as "service replacements", not as original equipment, on the earlier 24 stud engines, and can be found on many engines, particularly the "authorized" rebuilts. I agree on the cast block numbers, but the question was about heads.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2363 |
