silverchief | -- 11-01-2009 @ 12:58 PM |
My 46 is in excellent mechanical condition and was running fine in all respects. Now all of a sudden when I snap the throttle it stumbles or dies completely. Looking down the carb throat I see only a very weak spray from the two jets. I was checking for any vacumm leak on intake manifold, and only thing I did was very carefully tighten the connection at the carb about one eight inch. Can't believe that hurt anything. Any suggestions would be appreciated.
TomO | -- 11-01-2009 @ 4:25 PM |
Which connection did you tighten, the fuel line or the vacuum line? Hook up a vacuum gauge to the connection for the windshield wiper and use the following chart to help diagnose the problem. Tom
silverchief | -- 11-02-2009 @ 12:37 PM |
I tightened the vacuum line Tom. Thanks very much for the chart - I will hook up and see what it tells me.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=236 |
