Tim_Bowers | -- 12-07-2010 @ 11:36 AM |
Any extra left rear window regulators out there for the '37 Tudor? Thanks, Tim Bowers, owner Stellar Antique Auto Restorations www.stellarrestorations.com
Toms35 | -- 12-07-2010 @ 1:27 PM |
Have you tried bob drake reproductions? website is www.bobdrake.com and the number is 1-800-221-3673 give that a try.
Tim_Bowers | -- 12-07-2010 @ 3:44 PM |
Well, I see other years/body styles available in my catalogs, and a repair kit that will fix the one I have. Haven't seen one in a catalog however for a '37 Tudor. Thanks, though. Tim Bowers, owner Stellar Antique Auto Restorations www.stellarrestorations.com
Toms35 | -- 12-08-2010 @ 6:27 AM |
there is a place in minniesota that i have bought parts for my 35 tudor.he has a lot of old fords his name is doug paulson,rpm motorsports.his phone number is 1-888-223-1864 his website is www.rpmmotorsports.com he located in albert lea,mn.he has good prices on his parts nice to deal with. good luck in your search. he might be able to help you or lead you in the right direction.
trjford8 | -- 12-08-2010 @ 7:40 AM |
Tim, try Regulator Roy in New Jersey, Ph# 856-478-2527.He had some NOS ones about 3-4 months ago. He also adverises in the V-8 Times.
depoebay | -- 12-15-2010 @ 2:15 PM |
Stellar, Try Joe's Antique Auto for your '37 Parts. I was on a website that showed your in-progress restoration of a humpback sedan. Nice work! What can I expect to pay to have my '37 slantback done to driver status? I'm talking paint. I would send you pictures for your estimate. Mike
fordson | -- 01-12-2011 @ 2:06 PM |
Iam also looking for one, Bob Drake is in the process of reproducing the 1937 window regulator. It will be available middle of 2011. Worth the wait i reckon. Regards
supereal | -- 01-13-2011 @ 10:47 AM |
It would be more realistic to expect the Drake piece in 2012, than 2011, if they run true to form. The repair kits usually contain the crank parts, and if the teeth on the regulator sector are worn or missing, they can be rebuilt by welding on metal, then grinding it to conform with the rest of the teeth. It is also possible, in some cases, to remove the rivets holding the toothed sector, then turning it over and refastening it. Regulators take a beating because they are exposed to the weather. Rear wundows, in particular, are badly rusted because they get less use than the fronts. Most of the junkyard regulators we have bouight need major rebuilding, anyway.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2277 |
