johnmyron | -- 11-28-2010 @ 6:56 PM |
In process of complete restoration of 53 convertible. Considering hopping up flathead a bit as want to drive this car more than my 47 sedan. At this vintage, does a merc crank still have more stroke? Can it be added without other modification? Also considering adding better heads, polishing ports, etc. Will likely ad 3/4 cam for better breathing. Comments on what works please. Thanks, john wells
supereal | -- 11-29-2010 @ 7:52 AM |
John: There are Merc 4 inch cranks around, but often are pricey and need work. We ground one a while back for a customer in Illinois. You need the rods and pistons to complete the switch. Using a mild street cam and other modifications really won't provide much increase in power under normal driving, and seldom justifies the expense. The crank does provide some extra displacement, to 255, and more displacement equals more horsepower. There are some very good aftermarket finned aluminum heads available that will give you most of the boost without changing the block.
Stroker | -- 11-29-2010 @ 7:52 AM |
John: Yes, a 49-53 Mercury crank will provide a 4-inch stroke in any flathead engine. You will want to use the Mercury rods, unless you plan on buying special pistons, as the eye-to-eye length is shorter to allow for the extra stroke. Alternatively, you can run 21A rods, which will allow you to run the early style full-floating bearings, and still have the correct eye-to-eye rod length. If you opt to run your stock 53 Ford rods, just make sure your piston supplier is aware of the combination, so that they can provide the correct location for the wrist pin hole.
Pauls39 | -- 11-29-2010 @ 10:02 AM |
49-53 merc cranks had a 4 inch stroke giving you 255 cu.in. The stock cranks are available but pricey. All flatheads rods are 7 inches. Mercury pistons have the pin hight set 1/8" higher to compensate for the added stroke, otherwise the piston would stick out of the bore. Early rods, 21A can be used if the 4" Merc crank is offset ground 1/8" giving you about 263 cu.in. You must use full floating bearings which are getting real expensive and special pistons. I doubt it would be worthwhile in a street engine. Speedway Motors sells new cranks with up to 4 1/4" strokes. Bore the engine to 3 3/8" gets you 304 cu. in. Complete rotating assembly $1699.00. How fast can you afford to go?
Stroker | -- 11-29-2010 @ 10:33 AM |
John: I must have had a "senior moment". Paul is correct regarding the 7" eye-to-eye rod length, and both Super and Paul are correct regarding the scarcity of good 4 inch cranks. I'm also showing my age for favoring full-floaters, which of course your 8BA never came with. Ah, the "golden years". Long gone are the days like in 1957 when I walked into a Ford-Merc dealership and bought a new Merc crank for $125. If you go the Merc crank route, you will need the pistons with the .125" higher pin hole however.
proxie35 | -- 11-29-2010 @ 2:06 PM |
John, If you will go to my post (My 50 Coupe) You can see a picture of my engine. It has a Merc crank, 3/4 cam, finned heads, 4 bl carb & Air. I have One small problem with the engine. I've had several flathead experts ride in my car & they all say the problem is the cam.
Stroker | -- 11-29-2010 @ 3:44 PM |
Proxie: I see you are running a 50's vintage Rochester (Cadillac?) 4-bbl. What problems are you having, and why do you believe it is related to your "3/4 race" cam. What cam do you have? John: My reference to 21A rods and full-floating bearings are probably not valid suggestions today. I used 21A rods, because I stroked the stock Merc crank another 1/8 inch., and the smaller "big-ends" of the early rods meant that I could use stock bearings, and didn't have to weld-up, or metal-spray my cherry crank to match my now smaller offset journals. After 53 years, you'd think that the guy that uses the handle "stroker" would remember what he did. My flathead with a serious bore job, ended up at 296 cu. in., and I started out with a Weber 3/4 (F-1) grind, and decided that wasn't quite enough, so went to an Isky 404 along with 3-97's and Edelbrock heads. The 404 would probably be a bit much in a heavy car, but it jerked my 32 pickup along quite nicely. Let me add that increases in stroke do not affect the displacement as dramatically as increases in bore. Having said that, unless you want to pop for one of the "French military flatheads", or one of Don Fergueson's alloy blocks, you are probably better off just doing a clean-up bore, and concentrating on a good induction system; perhaps 2-97's or better yet one 4-bbl, some decent aluminum aftermarket heads, and a cam that allows you some decent mid-range torque plus a good set of headers, and free-flowing straight-through glasspack mufflers. Given the changes in carbs., you also might consider a Mallory or other after market ignition, as the original Ford only works well with a stock carb set-up. Paul: Thank's for setting the record straight!
alanwoodieman | -- 11-29-2010 @ 3:48 PM |
engine builders around here by the complete rotating assemble from Speedway to get the 4" crank, piston, rods, etc. If you really want a 4" merc crank, I have one that I will sell, I beleive there is also a complete set of 8BA rods, but no pistons. alan48@charter.net
proxie35 | -- 11-29-2010 @ 4:44 PM |
Stroker, My engine preforms Great. I could never explain my problem here, in type. Please email me your ph# & I'll give you a call & discuss my problem. fordpontiacman@msn.com
Pauls39 | -- 11-29-2010 @ 10:26 PM |
Proxie, It would be interesting to hear what problem you are having with this combination. I am building a Merc 60 over with an Isky Max-1 cam and Holley 4bbl to run in a plastic 34 coupe. Stroker, I know the senior moment thing, BTDT.
supereal | -- 11-30-2010 @ 9:09 AM |
We have seen several aftermarket cams with flat lobes, but the stock cams last almost to forever. That said, the usual reason for problems is not matching the carb to the engine to get volumetric efficiency over a wide range. We put four barrels on several flatheads, but they are 300 cfm rated, and perform very well. As to my comments regarding replacing rods with the 4" crank: it is important to know if the rod bearings are full floaters or inserts, and whether the crank has been ground down from stock, and can be fitted with available appropriate oversize bearings. When buying the whole set, you get fitted wrist pins, as well. If you don't have a shop or tools to fit them, it is a better idea to get the whole set.
proxie35 | -- 11-30-2010 @ 1:24 PM |
Ok Guys, I'll try to explain my problem. I can sure talk better, than type. Ha. My engine preforms great, I have a 390 cfm carb. When I'm going below 40 mhp & let the throttle all the way off, It seems as tho the engine is fighting the Tran. The car Jerks bad, I just push in the clutch & it is smooth. I can take it out of overdrive & turn the ignition off, the car will coast smoothly. Here is the Engine in the 49-50-51 (49 body,50 Grill & Trunk, Complete 51 Ceastliner Trim) I'll post pictures when it is fineshed. This enghine has everything the other has, except a stock Cam.
Stroker | -- 11-30-2010 @ 2:32 PM |
Proxie: Sorry we missed connections last night, I'll try again. Trailing throttle surging can be caused by either a lean mixture, or the need for a little more ignition advance. Can't tell from the photo's what you are running for ignition (kinda looks like a Mallory), but for starters, I'd bump the timing just a tad, while making sure it doesn't ping under full throttle. A cam with greater than stock "overlap", can make things worse as things get kind of chaotic in the intake manifold when the throttle plates are closed, and exhaust gas is "reversing" (for lack of a better word), into the intake tract. This is why many modern production car cam grinds have a wider exhaust/intake lobe-spread; in order to make them more "drivable". Traditional Hot Rod grinds especially for poorly-breathing flatheads have a narrow lobe angle, and "generous overlap" to give lots-o-time for air to get in, and exhaust to get out, with the hope that some of the exhaust will help pull in some more air. It looks like you are using the Rochester that originally were used on 52 Cadillacs. Given that this was a bigger (331 cu.in.) motor with overhead valves, you may simply not have enough flow to allow it to work properly, especially at part or closed throttle. If you are running a "big cam", this is sort of the nature of the beast, as trailing-throttle surging was not an issue with racers, as "racers" are supposed to keep their "foot to the firewall". You have certainly done a beautiful job of detailing the engine compartment, and I'd love to hear more about the A/C system you have installed.
supereal | -- 11-30-2010 @ 2:56 PM |
Check for a vacuum leak. That will do it. We just fixed a late model Merc with the same symptoms. The dealer told the owner his engine was shot. We found a crack on the bottom side of the intake manifold, which is made of plastic, and not the first time we have seen it.
proxie35 | -- 11-30-2010 @ 5:39 PM |
Thanks Stroker, I have Vintage Air Suppercool Pack on both my Fords, The one on the 50 does a very good job. AS you can see, I don't have the 49 completed yet. Sherrel
proxie35 | -- 12-01-2010 @ 3:15 PM |
Ok Guys, (I'm the Dumb A!! here) Thanks to Strokers post on the 29th, I corrected my problem today. The Time was 1/2" high on my engine. It's been that way for the past 10 years & performed great in every other way. Thanks Stroker. Sherrel
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2245 |
