barnsmith | -- 11-17-2010 @ 5:11 PM |
Just received my Walker Radiator part# FH-C-436-1. The top inlets are 1 1/4" the lower outlets are 1 3/4". The Radiator that came out of the truck has both inlets/outlets measuring 1 3/4" and it mounted to the grille perfectly therefore seeming likely to be the original. Anyone know if the Walker sizes are proper? This message was edited by SDExpoman on 11-17-10 @ 9:55 PM
37RAGTOPMAN | -- 11-18-2010 @ 5:45 AM |
I would call the vender you bought the radiator from, or Walker. [ maybe it was made for a different engine then the flathead ] and ask them, seems like a lot of trouble to hook it up as present, adapters will not look original, lets hear how you made out, 37RAGTOPMAN and KEEP on FORDIN,,,!!!!
SDExpoman | -- 11-18-2010 @ 9:57 AM |
I called the vendor Walker Radiators and explained the situation. They were very gracious and will take back the first delivery and send me another one.
nelsb01 | -- 11-18-2010 @ 8:51 PM |
You should have attached the picture of the front bumper here, so responses could see that you have a 1949 or later engine in a 1935/6/7 1/2 ton pickup. Not sure, but the hose sizes maybe different for a 1935/6/7 radiator than they are for a 1949 and later. With that, you may have ordered the wrong replacement radiator for your configuration.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2194 |
