chrismac | -- 11-08-2010 @ 7:46 AM |
I bought a 1940 Fordor with a more modern flathead in it. The heads are marked Mercury with the letters "EAC" cast into the center. Water outlets are at the front of each head. The engine has a distributor at the right front and a Ford 94 8BA carb. The block does not have a large bellhousing like the 1940 v8 block. What year and size is this engine? Thanks, Chris
supereal | -- 11-08-2010 @ 9:43 AM |
It is a '49 to '53 engine, 239 cubic inches displacement.
chrismac | -- 11-08-2010 @ 2:14 PM |
Thanks!
37RAGTOPMAN | -- 11-08-2010 @ 4:51 PM |
if it is a true MERCURY 49-53 ENGINE, with a 4 inch crank, it will have 255 cubic inches, if standard bore,and have 125 hp hope this helps 37RAGTOPMAN and KEEP on FORDIN,,,!!!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2144 |
