ole_Bill | -- 11-06-2010 @ 3:35 PM |
I plan to mount a water temp and oil pressure guage in the firewall so those parameters can be monitored when the hood is up and the motor running. Besides, they look kewl. I bought "mechanical" guages and know where to mount the oil pressure sensor. Where should the water temp sensor go? Car is '36 Sedan with street performance flathead.
supereal | -- 11-07-2010 @ 11:44 AM |
Usually the bulb is mounted in place of the two terminal stock sensor.
drkbp | -- 11-07-2010 @ 4:54 PM |
Port in the right bank water pump if you have a 21 stud '36 engine. Has a brass plug in it. Some water pumps for the 21 stud don't have the port for the senser but doesn't matter if you put them on the right bank. I have at least one of those. The later sensers are electric, two post, and I have not tried to put one on a 21 stud engine. Hope this helps, Ken
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2136 |
