pbc64 | -- 11-05-2010 @ 4:50 PM |
h*llo can anyone answer this for me on the 42-48 distributer there are two style rotors will the distributer accept both styles i understand the differences in the caps i am using the crab i just want to know if the shaft is the same thank you paul
oldford2 | -- 11-05-2010 @ 5:55 PM |
The distributor/shaft is the same for these years. If you use the earlier crab cap, the rotor is a little longer than the 2 piece cap which takes a shorter rotor. John This message was edited by oldford2 on 11-5-10 @ 5:56 PM
pbc64 | -- 11-05-2010 @ 6:16 PM |
oldford2 thanks for your answer paul
21JIMMIE | -- 11-08-2010 @ 7:52 AM |
I Have Some Of The Stainless Trim For The 1942 Ford. If You Need Any Please Call Me At 276 694-3981. 11-08-10 THANKS, Have A Good JIMMIE
pbc64 | -- 11-08-2010 @ 1:17 PM |
21 jimmie thank you but i have a 41 sedan with a 42 motor with crab distributer i found a bail style and wanted to know the rotor would convert i am looking for center hood strip and one scuff plate drivers front thank you paul
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2132 |
