ole_Bill | -- 10-14-2010 @ 10:37 AM |
On my 59A engine there are two threaded holes at the upper left (driver's side) rear of the block. One accepts the electric oil pressure sender. What is the other one? If I install an additional oil pressure guage under the hood, is this where the sender goes? If I don't use the duplicate guage, do I block this extra hole?
Stroker | -- 10-14-2010 @ 11:19 AM |
Ole: The 2nd tapped hole is for the supply line to the oil filter (if so equipped).
ole_Bill | -- 10-14-2010 @ 12:51 PM |
I have no oil filter. Does that mean I can use this threaded hole to measure oil pressure?
kubes40 | -- 10-14-2010 @ 1:02 PM |
You certainly may add a modern type mechanical sending unit to the second threaded port at the rear of the block.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=2002 |
