Fat40 | -- 10-11-2010 @ 5:51 AM |
I am stumped on what to do about my 46 still running HOT, took the car to a show yesterday the temp out side was around 90 on the way home. Maybe I will never be able to drive the car when it is that HOT out? I have read on the site that some of you can. I have a new walker Raditor,skips water pumps. I don't know what to do next. Any Suggestion. SID
Old Henry | -- 10-11-2010 @ 6:46 AM |
A couple of ideas: First of all, flathead engines just plain run hot. With the exhaust going back through the block before exiting, they just plain run hotter. Second, is the engine actually overheating and boiling over? If not, don't worry too much about it. Third, if it's not boiling over but the guage is reading real high, it might be your starboard (right) temperature sensor that needs replaced. Or, if you're still running 6 volts, it might be as simple as the wire from it to the port (left) side sensor being weak or a few strands broken, or even the wire from the port side to the guage having similar problems. Remember, 6 volts needs full wire size and conductivity. Any reduction causes the temperature guage to read high. I'm thinking that your engine is not really running dangerously high, even though the guage reads high, unless it's actually boiling over. At least, these are the experiences I've had with my '47. I drove my '47 on Route 66 in Arizona (from Provo Utah) last April when the outside temperature got up to 108. I just have the stock radiator and pumps. The gauge was always near or at the max but I never boiled over so I quit worrying about it. My 2 cents. Still Old Henry P.S. I assume that, for the summer, you have 1) removed the thermostats, 2) replaced your 50% antifreeze winter coolant with distilled water, one bottle of "Water Wetter" and one gallon only of antifreeze (for rust and corrosion protection. No, "Water Wetter" does not provide that in spite of its claims.) All of those things help. This message was edited by Old Henry on 10-11-10 @ 7:43 AM
TomO | -- 10-11-2010 @ 7:32 AM |
Old Henry is correct about checking the accuracy of your sending units. The right head sending unit (single terminal) controls the current through the gauge. The amount of current in the circuit determines the needle movement. The left side (two terminal) sending unit is a thermal switch that opens when the engine coolant reaches boiling point. Use a candy thermometer to check the coolant temperature and accuracy of your sending units. You car should run down the road at 180 degrees on hot days with no thermostats or 160 degree thermostats. If it is running hotter than that, the flow of coolant through the radiator is the prime suspect. If you have good water pumps and your radiator is clean, you might want to try the new water pumps that provide better water flow or a set of Skips pumps . If your cooling system is clean and you have good pumps, you might want to check your camshaft and crank gears for wear. Worn gears will alter the timing. If you have not had it done, I would also send the distributor out to be checked on a distributor machine, by a competent mechanic. If you are having this problem in heavy traffic, and not on the road, your fan is not doing its job. Tom
supereal | -- 10-11-2010 @ 12:36 PM |
Be sure to check the actual coolant temperature with a reliable thermometer to confirm the dash gauge indication. If the temperature is actually reaching, or near to, the boiling point, the usual cause is a plugged or limed radiator and/or block. As you have a new radiator, examine the coolant in the raditor neck for the presence of bubbles, which would indicate a compression leak, either a bad head gasket or block crack, as you run the engine. Removing the pump belt can make this easier. Also, check the exhaust system, particularly the muffler, which can be plugged with carbon, etc. If your car has an exhaust valve at the outlet of the manifold, remove it. Be sure that your brake system isn't building up pressure and applying the brakes. It happens if the pedal doesn't have the required free play. It is true that flathead Fords always had a reputation for overheating, but millions of these cars and trucks were built and ran, and do run, without the problem. My '47 can be driven all day in 100 degree weather with the heat gauge never much above the half way point.
Johns46coupe | -- 10-11-2010 @ 12:59 PM |
Not to hijack the thread but what is the purpose of the exhaust valve? My car has one but I'm not sure what or how it does it. Has dual pipes and one exhaust valve. John
Old Henry | -- 10-11-2010 @ 2:05 PM |
My understanding is that such valve is to divert exhaust to warm up the intake manifold for better fuel vaporization when it's cold but not after it warms up. Still Old Henry
37RAGTOPMAN | -- 10-11-2010 @ 5:27 PM |
FAT 40. did you install the overflow valve from SKIP.,? This is a MUST DO,when using his pumps,also take the thermostats out, and fill the radiator when warm, follow the directions, it might be that the coolant is low. is it foaming ? belt ajusted correctly, loose belts will cause the engine to run hotter, when slipping. lets hear how you made out,37RAGTOPMAN. an KEEP on TRUCKIN,,,,
Fat40 | -- 10-12-2010 @ 6:27 AM |
I have not installed the over flow valve from SKIP,will do so today. This car was a two year frame off restoration,am trying to work the bugs out. I got the engine from a close friend who had in a restored 46 and it was completly rebuilt.When I said it was running hot it did not boil over,but was near to the top. When I left in the moring to go to the show the temp outside was 60 the car ran in the middle of the temp gage and carried 30 pounds of oil pressure,on the way home it has maybe 10 pounds on the way home.The car has 50-50 antifreeze and no thermostats,distilled water,one bottle of water wetter. SID
Old Henry | -- 10-12-2010 @ 7:14 AM |
Sounds like your temperature and oil pressure are just like mine has been on my '47 for the 51 years we've owned it. Not too much to be alarmed about. Still Old Henry
supereal | -- 10-12-2010 @ 10:04 AM |
You don't need the overflow valve on a '47. If it is kicking coolant out the overflow, there is a problem that needs to be repaired. Installing such a valve treats the symptom, not the cause. My '47 will expel coolant until it gets to the bottom of the radiator filler, then never does it again. I run a 60-40 mix of Sierra antifreeze, and when it is heated, it has to expand. Thus, the excess is pushed out past the 7 pound cap. The valve is useful in a non-pressurized system. The purpose of an exhaust system valve is to force exhaust thru the passage under the carb to help warmup. There are two kinds: the one with the weighted arm and thermostatic spring, and another that looks like a "duck bill" that is inside the pipe. It has bimetal wings that are supposed to pull back as the system gets to opperating temperature. Most of the flapper kind eventually rusted in place, and if not fully opened, will restrict exhaust flow and performance. Both should be removed and tossed out. A common cause of poor performance and overheating is a muffler jammed with carbon. We have seen them so plugged that they weighed as if they were made of rock.
Old Henry | -- 10-12-2010 @ 10:22 AM |
Amen to SuperReal. I didn't know what the overflow valve was but if it's like a coolant recovery system, true, you don't need that. Just keep your coolant down 2-3 inches from the cap to leave air space to compress when the coolant expands and you'll never lose any coolant; unless, of course, you totally boil over. But, that really shouldn't happen with your set up. BTW the standard stock radiator cap is only 4 lbs., not the 15 pounders modern cars use. Even with that low pressure limit, I don't lose coolant. Still Old Henry
don1950ford | -- 10-12-2010 @ 1:18 PM |
Sid, if you have not already done so, i would highly recomend you call Skip and see how he can assist you with your cooling problem as you are running his high volume pumps. don
37RAGTOPMAN | -- 10-12-2010 @ 5:08 PM |
Just to let you know, I always lost coolant, I have SKIPS pumps, and installed his valve, and all summer never added coolant, its worth a try, just follow his instructions, fill it when hot to the top, you need all the coolant you can get in the system, leaving it low in the tank, provides less coolant in your system.whats that about?, just run the engine till it reaches normal temp and fill it, a clogged exhaust will also make it run hot, my 3 cents worth, 37 RAGTOPMAN an KEEP on TRUCKIN,,,!!!
shogun1940 | -- 10-12-2010 @ 7:21 PM |
buy a laser temperature gun and you can use it to check for your hot spots, I used to use oakite as cleaner in my youth to clean out the cooling system. TODAY I would probably use dupont rad. flush. The heat gun will tell you if the water is flowing through every thing evenly. good luck
Fat40 | -- 10-13-2010 @ 6:12 AM |
Thanks to all of you for all your infomation,I forgot I don't need the over flow valve from skip, when I run the new walker Radiator because of it has a 5-lb pressure cap.I am going to drive it again this week end and see what happens. SID
supereal | -- 10-13-2010 @ 12:12 PM |
SID: Take a hammer and tap the bottom of your muffler. If you get a "thud" instead of "tin can" sound, I'd bet on a muffler full of crud. Any restriction in the exhaust system can cause engine overheating.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1988 |
